Re: 12"gamefisher fiberglass repair help (pics)
update!
alright here is what i got so far!
bottom of the transom/back
around the very middle
the front bottom. i'm going to chip that out with my finger cause its all one big long crack
so other than some sanding around cracks to expose more fiberglass from the actual boat, for the new glass to grip onto, do you think its ready to start laying the new glass?
another thing i was thinking about. Oops mentioned
"one other thing......if you wish......you could grind out the entire hull.....and add a full layer of 1.5 csm....and a layer of 1708....if you did this......the boat would last for decades."
i'm not sure if i want to take out all the benches right now.
i know they need some work, which is fine and i don't mind doing but i just assume leave the middle one and front one in if i could for now. maybe cut a piece out of them to remove the old foam and and put new foam into them. take the back bench out and just add a piece of wood going across as the seat. kinda like the back of this one - i have to post the picture in the next reply, scroll down to see it, got to many pictures in this one
(do you think the two benches filled with foam would be enough to keep it afloat in case of emergency?)
so if i did this. what would be the best thing to do in terms of still making the boat last for decades? lol
what if (on the outside patches) instead of adding the csm, csm, 1708, csm, 1708, csm, 6 oz roving. as all small pieces - i did the first 5 layers as the patch work size, then after that a full layer of csm and 1708 over the whole bottom and some up the sides?
kinda like this guy did
http://forums.iboats.com/showthread.php?t=317761&highlight=fiberglass+gamefisher+jon+boat+12
would that help with the bulking problem?
the guy said he did it because there are a lot of cracks and nicks and ...cracks... all over the bottom of the boat and he didn't trust it. which is exaccttllyy where my head is at right now. but you guys would know what is best. he mentioned just glassing the inside and "gelling" the outside, i'm not sure what that means but i thought i'd mention it lol
would it be better for me to glass the inside of the hull on the sections that are in between the benches ?
on the inside floor after i take out the back bench - from the back to the middle bench, skip over the bench, from that to the front bench.
and just patching the parts on the outside that need it and leave the rest of the bottom/outside alone?
i know at some point i am probably gonna wanna take the middle bench out (but not the front, that one is fine) and build a nicer looking one out of wood as oops suggested, just right now i'm wanting to get her out on the water / be safer then prettier.
or should i just go ahead and take the middle bench out right now too.....lol
that would still just be glassing from the back up to the front bench, not the all of the hull.
which would still leave me feeling worried about the bottom anyway.
sorry if none of this made any sense or seems out of order, kinda just threw it all out there.
all thoughts and comments are greatly appreciated
