Re: 12 -24 without losing the 12
Not being one to give up easily on a problem, let me attack this from one more perspective. You mentioned your boating is primarily on inland lakes. In a 90% of the time situation, should you have to rely on this electric propulsion system, what would be the maximum range you would need to reach wherever it is you need to get to? Consider the bodies of water you are on very carefully. Are they remote, long and narrow, big and round/oval, river systems that connect multiple lakes, etc. My point in asking is that unless these are very large bodies of water, help is a matter of getting to shore which may be less than a mile in the vast majority of your trips. Having that same system help with docking is a complicating factor. Combining the two makes either one less than ideal. My feeling is still that for emergency propulsion, even a 9.9 outboard would be the most practical, would have unlimited range (based on fuel available) and yes -- they can be tied into the main outdrive and have separate controls at the helm but I also feel that is not necessary. You have an emergency! So what if your wife or another passenger needs to help in maintaining direction. You are not naviagating through a lock so this should not be a major issue. As for docking assistance, short of bow and stern thrusters, a simple electric wired or wireless trolling motor would be far more useful than an engine mounted electric motor. You don't need to carry a different fuel supply for the outboard if it's a four-stroke althugh a two stroke would be much lighter. A small 3-gallon portable tank of two stroke fuel would run that motor for about three hours at wide open throttle. Keep the fuel supply treated with Stabil or SeaFoam and it will stay fresh for six months or more. The long and short of all this is that unless your boating activities have some very unique distance or location considerations, I'm wondering if you are not being overly concerned about the need for a backup system. Inland lakes tend to have a fair amount of other boaters. Hailing a passing boater would result probably result in a tow to shore, to someones dock, or to the nearest marina/bar/restaurant. So the most practical and least expensive backup plan might consist of a hailer and a twelve pack of adult beverage. Save the other money for fuel.
