I have a 12/24 foot control trolling motor, Motroguide Brute 750 and am needing some wiring help. I am replacing a 24 V hand control motor. Here is my current set -up:
The postive and negative for both batteries one and two run to the front of my boat.
I have a three plug connector. Next to it is a switch that has a position for 12 V charge, 12V and 12/24.
The plug is connected to a box that allows you to adjust the motor speed.
What is strange to me is that only two wires go to this box. Both are 12 V. I thought you would need a ground wire going to this box also. (I assume I dont need this box anymore, because the variable speed is in the foot control).
I would like to set the new motor to run 12/24. But the switch next to the plug has me all confused.
Do I even need the switch?
Should I jumper the battery back in the battery box. Or does this switch do that for me?
Also, on the back of the 3 plug receptacle, where do I connect the red and black wires. There is a spot to connect on both sides of the plug and there is one spot that says ground.
Do I hook the 12V on one side and then the 24 on the other and connect the common ground to the ground?
Any help would be appeciated.
Thanks,
Crankit
Thanks,
Crankit
