I have a 1985 115 hp Merc inline 6. I took the lower unit off the other day to put in a new water pump. While doing this I noticed that with the water pump off the drive shaft had some play in it. Is this normal? Should I replace the top bearing that I could see with the water pump off? Can this be replaced by removing the water pump again?
