Hey y'all,
ok here is the situation, I went to start my boat to warm it up, and a large cloud of white smoke plumed into the air, not abnormal, except it was not stopping and the motor sounded like it was rough idling. It ends up stalling out. After that I would continue to try and start with the same ending shaking spuddering stop. The cloud I created did have a blue tint, not all white. There seems to be oil gas mix leaking out from under the top thinking carbs draining from motor on tilt. Also in the water there is a nice slick. This slick is new and I haven't seen this before. Everything ran fine and now 5 days later this happens.
side note. I did have my plug loosen and took on water over the back, it filled the bildge and almost over took the oil tank. I drained the gas tank and put a external tank for now. I didn't drain the oil because it didn't seem milky. It ran fine on land and driving back to slip.
Picture 1 is that of the pooling of gas oil mix in 3 outta 4 of the carbs, water picture show large sheen.
