I have a yamaha outboard motor that everytime you take off it seems fine until after about thirty seconds. Once it heats up the sensors shut it down to 1200 rpm then once it cools down the sensor goes off. motor poors out white smoke while the sensor is on. All the oil pumps and sensors are working. This is something probably simple that is just slipping by me. We did a compression check all cylinders between 116 and 120. Also motor is discharging water fine so that isn't a problem. Cant seem to pinpoint this one and it stinks cause i have a nice boat sitting there. Thanks in advance for the help
