My 2002 Mercury 115 EFI four stroke will only idle if I detatch the tube on the pressure regulator on top of the injector rail. I have to prime the engine mannually then it idles until I either put the tube back on, advance throttle or turn ignition off. I suspect the High pressure fuel pump. I cleaned the inline filter of significant sludge, checked the primer pump, cleaned injectors, checked fuel pump fuses. The pump does not make any noise when I turn the key on, however it does rattle when I turn it off.
Would it be correct to believe if it will atleast idle the ECU is operating correctly>
This boat has been sparatic at best over the past two seasons.
