Hi all,
Just purchased a 1982-1983 10HP Honda 4 Stroke. I don't have the owners manual yet so I hope someone can help me. I have been told 3 different things about the green light in front of the engine. 1.) It is a charging light that shows when the battery or lights are being charged. 2.) It is an oil gage/light. 3.) It is a temperature gage (green engine is running cool/red hot).
The other question I have is should there be a constant stream from the weep/pee hole or is limited water just dripping ok? It is not a constant stream, but the guy I bought it from had it in last year and had impeller, plugs, fuel pump, fuel filter etc replaced. If it should have a constant stream & impeller was replaced last year whats up? I have an older 72 Johnson (15HP) that does not have a weep hold & it just blows some mist from the exhaust I'm thinking maybe this Honda works on the same principal?
In general how are these Honda engines? With the motor I bought a 14 foot starcraft boat as well as a nice trailer, Trying to decide if the Honda is a good engine for this boat (seems alot quieter than the Johnson), or if I should throw the Johnson 15HP on and dump the Honda. Thanks in advance for any help.
Dan
Dan
