Re: ROUGH RUNNING 25 JOHNSON
Hard to put a finger on it without putting the eye on it first hard8. But we generally come up with some ideas here on the forums.....lottsa good wrenches here.<br /><br />Well....it's starts to cough and keeps on till it stalls....I still would like to know if cracking the throttle prevents this. If it does, we could be looking at a good air leak, either on the block or in the fuel lines.<br /><br />Were the tank vent, fuel line to the engine checked out?<br /><br />On the other hand, even though the spark is good on the spark tester, you could have a bad charge coil under the flywheel or a power pack heading south after the engine warms up.<br /><br />Did the wrench check the fuel lines to be tight and not obstructed? Was the fuel pump checked? If the diaphram is busted, you may not be getting the gas needed to run. Here's something for you to try. The fuel pump is the triangular shaped box on the side of the engine with the fuel lines coming and going from it. Remove the two screws securing it to the block and pull it away a little. Now pump the primer bulb and see if any fuel shoots out the back of the pump. If it does, the pump is shot.<br /><br />Take a look at the above and see what ya' see. Again, without being there, all we can do is suggest what to look at. Hope you find the problem from the above.<br /><br />Keep us posted.....thanks.
