The last 2 years I've had problems starting my 1982 Evinrude 115 hp engine.It's hard starting and when it starts runs for a few seconds and cuts out.I've also noticed when it starts sometimes it tends to sometime sneeze out of the exhaust.When it starts and I push up the high idle lever it tends to cut out also.When I get it started and put it into gear it also stalls sometimes.When i get it going it runs fine at high speed.If it lays for a while same problem all over again. Has anyone ever had the same problem and maybe a solution.It's really starting to get annoying.
