  #1
Old June 1st, 2003, 04:59 PM
united jigsticker united jigsticker is offline
Default 1999 50 hp tiller Evinrude 4 stroke problems
Hello all,I own a 1999 4 stroke 50 hp Evinrude tiller.The motor ran decent upon purchase, except for some smoking upon start up. At the 20 hour check they adjusted the valves and said everything was ok.After this visit, the motor still smoked upon start up and also developed new problems.While going across the lake at WOT, the engine would cut out, and cycle as if you hit the rev limiter in nuetral, causing the boat to come off of plane abruptly. The motor would not kill or stall when this happened, and after shifting to nuetral and back to gear I could take off again.This happened on an intermittant basis, typically if weather temps were above 70 degrees and I returned to dealer for warranty work about the concern.After 3 trips to the dealer, and the change of the main brain box, inspection of throttle and gear linkage and sensors, and a full water pump and cooling system tear down and inspection by dealer, a full motor inspection and numerous hours of tank testing, they told me the motor is fine, no problems, yet the problem still occurs.Also, since my lasy "warranty" visit, now when coming down off of plane normally, the motor will stall out if the throttle is backed off of too quickly. This is a new issue that developed immediatly after I had it in last.The motor still smokes upon start up, and on hot days or after running at 3/4 throttle or above can be very hard to start or re-start.Also, I checked the oil and now the level is HIGH with the scent of gasoline in it. Wondering what could be the cause of gas getting into the crankcase.The motor has been to the dealer under warranty for all issues except for the gas in the oil, and they say there is nothing wrong with it. The warranty expired and the dealer told me they never want to see that motor again.thank you for any ideas or suggestions in advance, it is greatly appreciated
  #2
Old June 1st, 2003, 05:40 PM
Fouled Plug Fouled Plug is offline
Ensign
Default Re: 1999 50 hp tiller Evinrude 4 stroke problems
Is this a carbed or injected motor? Sounds like you are dumping too much fuel into the engine. As to the warranty, does your state have a 'Lemon Law'?
  #3
Old June 1st, 2003, 05:59 PM
The motor is EFIthanks
  #4
Old June 1st, 2003, 07:48 PM
JB's Avatar
JB JB is offline
Someone is blowing smoke at you, UJ.The ECM records any failure and gives the wrench the code for what happened.Your dealer "skated" on you. Get a lawyer.
__________________
RED SKY at night. . .
JB
  #5
Old June 2nd, 2003, 11:24 AM
So, they say they never want to see it again, and after each trip to the dealer I end up with another problem on top of another.The ECM records everything, just as the diagnostic systems in vehicles nowdays..that's what I gather.In other words, they don't like me, and have &%$#! my motor up....thanks for the reply JB..I will see what I can do.
  #6
Old June 2nd, 2003, 12:48 PM
So you think they never did any of these tests??? It just seems like it would be a waste of time when they know better.Perhaps they are sabotaging the motor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1999-4-stroke suzuki idleing problems ANGLERWELDER Yamaha & Suzuki Outboards 4 February 27th, 2007 06:40 PM
1999 Mercury 30 Hp 4 Stroke Tiller tinman283 Mercury & Mariner Outboards 0 August 16th, 2006 10:42 AM
1999 Evinrude 5hp 4 stroke no spark mykissmania Johnson & Evinrude Outboards 3 March 21st, 2006 01:30 PM
1999 Evinrude 5hp 4-stroke problem mykissmania Johnson & Evinrude Outboards 0 January 3rd, 2006 02:27 AM
Smoke ? 1999 Evinrude 70 Four Stroke neumanns Johnson & Evinrude Outboards 2 July 24th, 2003 06:40 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
