tilt is non-hydrolic make.<br />tilt was working then after 1 month in my driveway it was not raiseing all the way and sounded laboured when raising only. checked battery (was fine), all cables checked and fine. leg was 25% up and when tryed to lower it to remove tilt stoped working, the mottor that powers the tilt didnt work at all. now i can,t remove the tilt to service it.<br />should i try to fabricate something to fit into my drill to stick in the hole to lower the the leg?<br />what should i do next ? the model is a 250a /sp volvo penta (aka 151aq) i can here the click in the electrical box on the tilt when i try to operate it. also the 40amp fuse on my engine block is fine as well. i didnt want run jumpers directly to the tilt motor (to test it) because there are 4 female holes and i dont know wich are ground and didnt want to fry the motor. ty for your help
