2 Speed Minn Kota ?? (older type ?)
raf235
Hi<br />I'm trying to check out the spec of an older Minn Kota that I've seen advertised for sale.<br />It has the previous non-streamlined control head, a single transom clamp, and parts of the description are:<br /><br />'weedless 10' (I guess this refers to the prop)<br />'two speed' (can this be right ?)<br />'8lbs thrust' :rolleyes: <br />'weighs about 8kg'.<br /><br />Is the thrust right ? did Minn Kota produce an 8lb thrust motor that weighs 8kg ? (and if they did, I suppose 8lbs of thrust would be pretty useless....)<br /><br />Apparently the model number is 10W and the serial number is 21750...<br /><br />Any help much appreciated :)
