The throttle cable and shift cable were both replaced 2 months ago on my 1976 Sea Arrow 302 888 mercruiser. When shifting into forward and reverse the gears are grinding at times. Do you think the cable should be adjusted?
You're probably not shifting quick enough. Your shifts should be brisk.
If you are experiencing this 'grinding' on the muffs...tis to be expected as the shift interrupt switch will not function without a prop load.
