Hi everybody!!!<br /><br />I have found a problem (or so I think) on the transom of my 20' Center console Sunbird. While I was installing a new transducer and speed sensor yesterday, in a couple of the wholes I drilled I either had a bit of water come out or the drill bit came out wet. What was estrange is that out of 4 holes I drilled in a 3X3" area, only one of the wholes was wet. The other one was on the speed sensor. Again, only one of them had water. The transom seems to be very solid. No stress cracks or week areas. I use a 150HP motor and I don't see estrange behavior on the transom when the boat is running.<br /><br />The question is, what should I do? I don't want to take any drastic measures if the problem is not big enough. <br /><br />Please let me know what you guys would advise me to do.<br /><br />Thank you all.
