Limited-Time
- Mar 30, 2005
- 5,820
So here is the situation: The laundry room is on a slab with all the drain and supply lines running through/under it. The washing machine and 2 sanitary tubs are serviced by the drain line. The drain line exits the slab into a basement area and continues over head until its run into a larger wast line and dumps into the septic tank. The drain line "sleeved" by a larger pipe for some distance in the slab before it exits into the basement area. It is visible in the basement and I will post a pic later today.
Now here's the problem. On occasion when the washing machine is emptying, water will flow out of the larger "sleeve" pipe flooding a portion of the basement.
Here's the catch, to does not happen every time. You may do several loads before it leaks, it may leak on the first load of the day. Or it may not leak at all for several loads. The only constant is when it does leak its gallons during the pump out cycle of the washer. The amount of water coming out between the "sleeve" and the drain line is what you would expect if emptying a bucket through a 2" pipe.
http://
http://
