OMC 3.0 misfiring when hot/after being under a load
kbibeau1
I have a 1987 omc 3.0 with an omc cobra drive.
The problem I am having is after about 40-50 mins of runing the boat under a load it will start to misfire intermittently. The boat has always charged about 15Volts, which I had thought to be a bit high.
If i adjust the tilt while under a load it makes the skip much more noticable which leads me to believe that it is something electrical. I have already replaced the following:
-coil (from local auto parts store,not a marine coil, does it matter?)
-plugs
-wires
-distribuor cap
-rotor
-condensor
Could this be a bad resistor/regulator?
If anyone has any ideas please help and thank you in advance.
Levinz11
Re: OMC 3.0 misfiring when hot/after being under a load
-plugs
-wires
-distribuor cap
-rotor
-condensor
Points...Change the points.
bryancurit
I have the OMC 2.5 and am having the same problem. I have changed every ignition part and have had the Carb rebuilt. Mine always does it after twenty minutes and after I come down from running fast. Mine also got worst when I trimmed the motor. I went back and checked it to find it was number 4 cylinder skipping. Eventually it goes from just 4 to running so bad I can't keep it idling. I let mine sit for 20 minutes and it started right up and ran fine again for another 20 minutes. I should also mention that I had found a cracked plug on number 4, I replaced that but still have the same problem. I was told to check the exhaust manifold and riser elbow to see if they were rusted out or cracked and letting water into the cylinders through the exhaust valves. That would make sense since number 4 cylinder is the back cylinder and is the lowest in the especially when you tilt the motor. I haven't been able to find any cracks or water leaks though to prove this. Any suggestions would be appreciated.
kbibeau1
I will let you know if I can find any solutions to this. I plan on checking/cleaning all my connections today and testing voltage at the coil. Hopefully I can find something to help the both of us.
Levinz11
Also check the voltage on the + side of the coil while the engine is running. Should be 7-9V. If it is getting more V's that may be overheating your coil and causing it to cut out.
kbibeau1
Mine is getting 12-13V! I am guessing that is more than likely te cause of my problem. I am guessing that is due to a bad resistor? Where would I find a replacement?
Thank you!
Levinz11
You have a couple options:
-Get a coil with an internal resistor OR one that runs on 12V constant
-Make your own resistor wire
-Wire in a resistor
Do a quick search in this forum for more specifics as I have never done any of these suggestions.
bryancurit
You need to be careful about just wiring in a resistor, as far I as I know these ignition systems use the full 12V to the coil during starting for a hotter spark and then switch to across the resistor to drop it to around 8-9V while running. As another note, I'm not sure how trimming the motor would cause a misfire if the problem was just too much voltage to the coil.
kbibeau1
Do any marine stores/websites carry the OEM resistor?
Levinz11
There are 2 wires to the + coil term. One (forget the color) supplies 12V while cranking only. The other (purple) is a ballast/resistor wire coming from the alternator.
If some one "rewired" his ignition and he has an older alternator supplying those volts, I can see how hitting the trim might cause the symptoms he describes. Old wiring can cause all kinds of weird issues.
Levinz11
The resistor wire is in the harness and would be tough to change. Coils are pretty cheap. Get one that runs on 12V constant or has internal resistor and wire it directly to the alternator.
kbibeau1
With engine running?
Yes it is actually closer to 14V with the engine running. I am going to try a coil with an internal resistor. Will let you all know how I make out.
Thank you all!
kbibeau1
Replace with internal resistor coil and still have the problem. I'm at a loss :mad:
Levinz11
Well if you changed the points and everything else on the ignition....time to start looking at the fuel system.
bryancurit
Same here, I'm still having the problem as well after replacing the coil with a 12V version after finding almost 13V at the + side of the coil. I have already rebuilt the carb and fuel pump, I am starting to lean toward vapor lock, just not sure what is causing it.
bryancurit
Kbibeau1 did you ever come up with anything?
58bang
I have the same problem with my 1977 3.0 OMC Sterndrive motor. I have replaced points,coil,condenser,resister,cap,plugs and also replaced the ignition switch and fuel lines. Could a misplaced wire cause this misfiring??
I disassembled and rebuilt the motor so I may have mixed up a wire connection?
