Ok I will start with a little back story. I bought a 87 thundercraft with a 3.0 mercruiser and alpha one gen one outdrive. That was about 5 years ago and since I was totally new to boating I made a few rookie mistakes. First off I bought what turned out to be a rotten boat, and to top it off I failed to properly winterize the outdrive:facepalm:. The next spring I noticed the lower gear case was split in half. not having the funds to replace it i decided to rebuild the boat. Long story short 4 years latter boat in pieces (still) and I lost the ambition to do anything with it. A few weeks ago I had had the chance to get a FREE solid boat minus motor and drive I also bought another drive to replace my cracked one. while removing the upper cap on the drive I broke a bolt resulting in the case cracking (just my luck). Ok back to my topic I have my old motor in the new boat and almost all wires/plumbing hooked up. Its been 4 years since i last ran this motor and it ran fine when I winterized it (properly). I would like to know if it will run before I put much more money into a lost cause. Is it possible to run water to the motor without the drive hooked up? I don't want to even try to turn it over without some sort of cooling.
Thank you in advance for any help
Tim.
Tim.
