Re: Boat Speed Bass Tracker Tournrment TX17?
Musky Killer;
I just looked over the thread here again and noticed that you are using a Hydrofoil. Someone mentioned that it may cost you some top speed as it could be creating Drag if it is touching the water. He also mentioned that you may want to raise the motor, and use a jack plate.
Let me give you my take on this.
1) the hydrofoil is rigid therefore the faster the boat the more lift. Lifting the motor to raise the hydrofoil out of the water is possible but tricky because if raised too high the prop may ventilate easily, and the water flow to the engine could be reduced. The cavitation plate should be about 1 " above the bottom of the boat at the "V".
2) The cavitation plate is designed to keep the water density at the top of the prop the same as it is below the prop. this keeps the prop from ventilating.
3) Lifting the back of the boat too much at higher speeds (ie; Hydrofoil) does not produce as much drag in the rear of the boat as it does force the bow down. At cruising speeds and above, the bow should be about 5 to 6 degrees up so that the boat rides on the rear 1/3 of the hull (behind the helm). With the bow too far down you will notice reduced speed, sensitivity to a port side list (lean), and sensitive steering, and it will lay over on the gunnel in turns.
4) The most efficient position for the motor (prop) is as close to the running line (X dimension) as possible so long as the prop does not ventilate. In other words you want the prop to push straight forward. The further down into the water, the higher the bow rise on acceleration. A jack plate allows you to move the motor up and down to "center" and find the best height, and they are more effective when they incorporate a set back. Moving the motor back 6" to 10" allows you to raise the motor to ride inside the wake behind the transom. These jack plates are pricey.
My suggestion - remove the hydrofoil and determine what the base line is. The boat is likely to run a bit faster, It is also likely to porpoise when you trim the motor out, have a high bow rise and slow acceleration to plane. If so, add Smart Tabs. They will eliminate porpoising, improve acceleration to plain by 40% (eliminate the "Hole" in "Hole Shot" ), and allow you to trim out for a better prop position. They will also improve ride and handling, and tracking. Don't change the prop because the RPMs and speed should increase when the boat runs smoother.
As for water in the foam, that could add weight but it would need to be significant to make a noticeable difference. Pull some of the flooring panels and feel the foam.
Yes I make Smart Tabs, but I am not here to sell one set of tabs, I promise. What I want to do is help you understand the problem and fix it so you can enjoy your boat.
