Re: Trim Gauge function...
That is BS
They are totally serviceable, and easily at that, get your nose out of the book and under the hood.
well, the reason they don't recommend disassembling or splicing the wires is due to the fsct there is voltage passing through the wires and sending units
once they are opened and comprimised, there is a much greater chance of allowing stray current into the water which leads to massive corrosion issues, boaters already deal with corrosion due to the fact that putting a large piece of metal into water basically creates a battery and thus corrosion
this is mercruisers way of alleaviating an already prominent issue
oh, and by the way - usually the only reference i use the manuals for is a specific torque spec i have forgotten, otherwise i have read, studied and been tested thouroghly on mercruiser manuals, and i spend more than enough time "under the hood" to feel confident posting relevant information on this board
