I de-winterized my 2000 Chaparral 5.7 Volvo Penta GL friday and went to Canyon lake. After about half a day of cruising around we we on plane about 35mph when my wife started yelling that something was wrong. I immediately stopped and shut off the engine.
As soon as I stopped I could see smoke and smell burning oil, that's when I looked down and noticed the temp gauge was pegged. I turned on the blower and cleared the engine well of smoke and let it cool for awhile.
After about 10 minutes I opened the engine cowl, got some tools and started trying to figure out what happened.
The raw water pump was extremely hot to the touch, I left it alone to cool awhile. The recirc pump was extremely hot, recirc coolant hose was really hot and definitely under pressure, grey oil smelling smoke was pouring out of the valve cover breather, so I gave it an hour to cool before doing anything else. After it cooled a bit I restarted the engine, it took a few cranks, its usually easy to start, and started heading in. After about 1/4 mile, the temp needle started toward the red again so I shut it down.
After it had cooled again I took the front plate off the raw water pump, it was my first suspect. It looked fine, impeller still looked new. I jumped overboard and and checked the drive unit, no blockages or garbage bags or anything else blocking the intake ports. At that point I thought either the recirc pump was bad or the thermostat was bad so I got towed in and went home.
Next day at home I pulled the recirc pump and checked it, perfect condition nothing wrong there. Next I took the thermostat off and tested it in the kitchen with a pot of water and a thermometer. It started opening at 165 and was fully open at boiling temp. No prob there.
So I decide its gotta be a blown head gasket and pull the heads. I noticed when I removed the intake that the center bolts werent very tight, maybe 5-6 ft lbs at the most. I pull the intake and heads and the head gaskets are also in good shape, no signs of a blown head gasket. Once I got the intake off it was obvious that a lot of water had got into the crankcase, full of chocolate milk colored gel. So at this point I'm thinking cracked heads or block, but then it wouldn't have run half a day before ****ting the bed. The #8 cylinder shows seizure indications the other 7 are fine.
What else can I check?
