This is my friends boat that I am helping him fix. He has the money, I have the tools and time.
We noticed a leak under the exhaust manifold and assumed to be a cracked manifold, gasket or block. When I pulled the manifold I could not find any traces of cracking or leakage on the gasket surface. However there is a lot of rust stains above and below the front port freeze plug.
Question. Could rust stains be an inch above that plug or maybe am I missing a gasket leak. We could not see the source of the leak while running, which was a pretty good stream, and now I have the manifold off. Should I go ahead and replace the plug.
He drains the water every season and is a fresh water boat.
Thanks for your thoughts
