Re: Fuel Tank Question
I just went through the same thing. My pickup tube stopped picking up after the gas dropped to ? full. I suspect the plastic part of the tube assembly weakened and broke away.
I tried to remove the angle fitting that screwed into the large nut but gave up when the welded insert (Plastic welded to a plastic tank) in the tank began to give way. I chewed up the angle fitting at the same time, so I decided to cap it off using a piece of 2”, or so, PVC pipe. I drilled and tapped into the angle fitting, and made a circular cap somewhat larger than the pipe. I then assembled the piece of pipe over the fittings and filled the cavity with Goop. I then drilled a hole in the cap (made from using a 2 ?” hole maker and a plastic cutting board). I screwed the cap down with a screw. I "Gooped" all around the cap. Nothing will ever get through the seal.
I then bored another hole next to the Fuel Pickup hole and installed a bulkhead fitting and made a copper pickup tube than screws into the bulkhead fitting.
I can supply the fitting info if you intend to go that route.
Hopefully the fitting can be removed without the difficulty that I had.
Incidentally, did your tank recently develop gushing out the fill tube?
