dkonrai
- May 9, 2009
- 719
this is the first lower unit that i cant get the bushing out the normal way (shaft bushing tool). i threaded the bushing (5/16) then used a bolt and puller to yank the bugger out. can i just reinstall the bushing? or should it be replaced? i decided that i would try the thread the bushing trick before drilling out the housing.
i am going to do another lower unit, is this the normal route to remove the bushing? or should i have drilled out the housing with a 5 1/6 bit? housing hole is only 1/4" so the shaft tool bottoms out on the housing and doesnt push the bushing out.
manual shows a extractor, or slide hammer but i havent seen a slide attachment that will fit in a 1/4" hole.
thank you
dino
thank you
dino
