Thanks in advance for your help everyone.
Background: I have a 1976 35' Silver Queen houseboat I just bought in this current state. I have drilled into the stringers in a few places and found some wet wood. The wood is worst in the deepest part of the V where water collects. The stringers appear to be just 2x4's across the width of the boat, with unglassed 2x4's tapered into the top, for the floor. I have never seen stringers that just run side to side, usually you see something more substantial front to back. The wood in the stringers is still firm for the time being and the glass appears to be more substantial than usual. Probably two layers of 24oz roving. I can kick them and they don't move. Also the original builder did a terrible job getting the glass to the end of the stringer, most are exposed but still solid. The hull is solid around 3/8 and 1/2 solid fiberglass from that same heaving roving.
Stringers:
1: Do I gut them all out and replace with same simple 2x4, and similar glass. Maybe change to epoxy and biaxial?
2: Do I count the wood as lost and glass over the existing stringers with several layers of new glass and hope the glass casings will be enough strength. I would also tab in the upper uncovered 2x4's to add additional strength.
3: Do I sandwich new 2x6's to the stringers and either glass or through bolt them onto the existing part? I saw this on a YouTube diy network houseboat remodel show.
4: Some other method. The reason I don't want to gut and replace if possible is there are a lot of stringers in the boat and if I don't have to do demolition work that would be nice. I hate to destroy whats there, it is providing some strength. The stingers are holding the boats shape on the stands right now so I don't think I could cut them out all at one. It will only be a displacement speed boat so I'm not terribly worried about weight.
5: Any alternative materials I should use beyond fir 2x4's
Foam: It appears that this boat never had any. If I were to add float foam I don't think I have space for the cubic feet required for a boat this size. What are your recommendations and laws about this in a boat this big. Do I bother, or add as much as I have space for and hope for the best? I have considered using Styrofoam up to a 1/2 inch of the stringers and floor, and using a high density expanding foam to fill the gaps and make a solid structure. I did that on my Supra and it worked really well.
Thanks so much. I'm sure I will have more questions later.
Stringers:
