Magneto Coil replacement 1961 McCulloch Royal Scott
Good evening All.
Title says it all. I just bought this motor a couple weeks ago.
I am a newby, so please, easy on the abreviations (smile). Newby: meaning this is the first boat motor I've ever touched. I've had my old cars and did all the work myself, just never had the fortune of dealing with a two-stroke/smaller engine.
I don't plan on ripping into this motor, not by any means. I simply want to replace the crusty wiring, already ordered my kits for the two Carter Model N carbs, the ignition coil, the water pump (not figured out where it is yet, but I'm just working from the top-down right now) and my first order of business... the "magneto coil" (two of them).
I've not seen them anywhere on the internet. Any suggestions on finding a direct replacement? Anyone know what I could use as a replacement?
(The photos show where she was when I bought her, the Magneto Coil, and the wiring to the ground and the magneto.)
Thank you in advance for being willing to share,
Joe
Willyclay
Re: Magneto Coil replacement 1961 McCulloch Royal Scott
Welcome to the iboats.com forum! The members here are great and the experts, which I am not, can help you with any questions about that great old motor. The link below will get you to some service info for your motor. Good luck!
http://forums.iboats.com/boat-topic...nline-service-info-not-just-boats-393281.html
Login as directed then drill down to: Small Engines, Marine/Boat Motors, McCulloch and, finally, Royal Scott.
F_R
I don't think that is a magneto. It is battery ignition, similar to cars of the day, except a separate coil, points & condenser for each cylinder instead of one coil and a distributor. You can use car coils if you can figure out a way to mount them.
That would definitely be good news. Makes sense to me.
Thank you for your input!
torbjorn
Late response but maybe better late than never. I just got a 1960 model 40 running, same setup. Battery ignition, I can tell you how to wire it to an OMC key switch. Replacing all the wires coming out of the flywheel is simple and necessary. I can also tell you how to set the metering rods on the Cartr N carbs. Let me know.
