I have a 1964 65hp 4 cylinder 2 stroke which only sparks intermittently. I have new spark plugs, condencer and points. When I test the spark plugs leads I get the odd random spark that is bluish in color. I have some months ago tested sparking at the points by spinning the distributor shaft using a drill (on the bench) and got regular sparking. I am about to pull the distributor off again but thought that someone might a a thought as to what is going wrong between the points and the plugs ( I have disconnected the mercury kill switch, and added extra earthing from powerhead to distributor. Any ideas please?
