distribution housing
scoflaw
Ensign
Can't seem to find an exploded view of this unit.
My question and concern is that the air actuated drain valve might open under way and flood my ER with raw water. Is that possible?
Grub54891
Re: distribution housing
Any boat with or without that system has the possibility of flooding due to a broken hose or failure! That's why we keep up on the maintenance religiously. Make shure all hoses and clamps are secure and not cracked,ext.
grub
MarkSee
Your boat should have 2 high volume bilge pumps so if you start to take on a lot of water, you would see both those pumps flowing water out the stern sides before getting flooded.
I manually test my pumps turn on every couple of trips.
Mark
scoflaw
Ensign
Looking for someone who had a working knowledge of the distribution housing not what to do after the horses are out of the barn
