Seat Back Separation
Thomv
I have attached a picture of the back of the front seat where the two vinyl cushions have separated from one another. Just wondering what type of adhesive would work best in getting them glued back together. The previous owner tried something that obviously did not hold up to well
jbcurt00
Re: Seat Back Separation
Are you sure that there aren't some sort of mechanical fastener holding that yellow & blue (?) bolster cushion to the white cushion?
Either screwed/bolted from behind or friction clips? Similar to these:
Thomv
I will have to check.
tpenfield
+1 on the mechanical fastener . . . maybe somewhere underneath the main cushion.
Yacht Dr.
If your main seat has wood on the side .. the a screw and a snap cap should do it.
YD.
