I drained the gear oil, removed the six bolts, and the lower unit dropped down maybe an 1/8th of an inch, and that was it. Wiggle, pull, it did not come out. What am I missing?
While at this, where do you find the model number on the Johnson 9.9? I've looked and can't find anything but stamped part numbers. It has electronic ignition as what info I've found states that it is 1994 or later. Correct me if that is wrong.
Thanks
John
Thanks
John
