Think about this. How many lock washers do you see in the assembly of an outboard motor ???
I've seen quite a few....
But I'd agree 100% that I've NEVER seen one used on a flywheel nut. I don't know why either, but there must be a reason.
Rethinking this....
I quite cavalierly thought of lock washers on carb float bowls...and some other places....but I do a lot of tinkering with small air-cooled engines and I may be blurring recollections.
I am now thinking of one specific O/B...and all repairs that I have done to it....and cannot think of a lock washer anywhere. :redface:
So is there a reason that they don't need lock washers?
Lots of things were done different back then. They used to put cars together with carriage bolts, and close was good enough in many cases.
Lock washers shouldn't be used in an application where accurate torque is required.. Modern times, you'll almost never see it.. Lock washers are used when things are just snugged tight and do not require accurate torque. This would be the " close is good enough " case from the past
proper torque on all the fasteners does the job.
..and every time I see the title of this thread i can't help thinking "man...and they tell you in the Operators' Manual to keep your fingers away from the flywheel..."Re: nut on the flywheel
