dustin2550
- May 17, 2008
- 35
Last week my bilge pump fuse blew. When I replaced the fuse. The motor's trim fuse blew..... when I replaced it the stern and bow fuse light blew. When I replaced the fuse for the lights the stern light now stays permanently on and cannot be turned off by the switch as the console, and the bilge blew again. I am thinking of rewiring the entire system from scratch. Before I do that, is there is a simpler solution I should check first? I feel there might be an issue with the wire from the fuse panel to the battery? Would this be a fair assumption?
