I need help ! 40hp evinrude
Tn upsman
First off I'm new to the forum, so thanks for any help! I'm lost. Bought this boat, took it out, ran fine, so I bought it. Been having trouble ever sence. After running for a few minuntes, maybe 5 the alarm starts sounding, so I shut it down turn it off gave it a minute, restart and it will run but will not pick up. If you give it throtle it is very slugish and boggs down. Now if you let it set for a long period of time it will pick up and run but then will do the same after a short time. I realized I had the air valve on the gas tank closed so I opened it. This was after I was back at home. Could this be the problem.
New day, Went to lake to try my idea. Boat tried to start, it would run for a second then shut off. Then it would try and start but would not fire off, finaly ran the battery down and brought it home. Stop at store on the way home for new spark plugs because I figured those were fouled, I was right, they where. Put in new plugs and tried to start it but it just spins like it wants to start but wont. So I'm lost and this may make no sense to anyone. LOL but if it does and I can explain further to someone. I would love the help.
Thanks
Fleetwin
Re: I need help ! 40hp evinrude
The alarm is probably "overheat". If you do not know when the water pump was serviced, you're overdue.
First thinhs first.
-Do a compression check. No sense throwing parts at an engine that may be damaged. See the "top Secret" area of this section. http://forums.iboats.com/showthread.php?t=299680 It will explain how.
-If that's OK, you need to replace the water pump.
-Clean and rebuild the carburetors.
-Check for good crisp spark. That is also explained in the sectioned mentioned above.
birky063
40 hp evinrude alarms
MY EVINRUDE IS A1996 MODEI 40 HP. I HAVE THE SAME PROBLEM WITH MY, WATER PUMP WORKED OK , OIL RESIVOR WAS FULL, THE PROBLEM WAS THE VRO PUMP REPLACED THE VRO PUMP AND WORKED FINE FO A SHORT TIME AND DID THE SAME THING AGAIN, SO WE UNHOOKED THE VRO PUMP AND MIX GAS AND OIUL NOW, AND THAT WAS 12 YEARS AGO AND I STILL MIX THE GAS AND OIL WITH NO PROBLEMS :mad:
Tn upsman
First thinhs first.
Thanks for the ideas. The top secret area is full of knowledge. Now if I can just be smart enough to figure it out
Tn upsman
Re: 40 hp evinrude alarms
That has also been done to this engine!
