Re: 1987 Procraft 1660v Soft Floor
Welcome to iboats, does the 1 your considering look like this:
Read thru
Gt1000000's thread, he's doing some really great work on a bass boat & has lots of good pix & text of his resto-work.
Because of it's design, bass boats are somewhat more difficult to get the cap off of, when compared to a runabout style hull. Much of the interior is integral to the cap. 1 continuous fiberglass surface from the port rubrail, up, over & down the gunwale, across the deck and up & over the other side of the boat to the starboard rubrail. Same from transom to bow, typically 1 continuous fiberglass surface.
You should not take a firm transom as completely safe & sound as it appears from the outside. The interior plywood could still be wood mulch, and as long as the previous owners were careful, didn't rapidly throttle up to WOT & rapidly back to idle and didn't power load the boat onto the trailer, there may be no exterior cracking of the fiberglass or gelcoat.
If you decide to take another look at the boat, and possibly move forward, give the motor an extremely thorough going over, if it fires & runs or can be made to do so, relatively quick & inexpensively, grab the boat & all. If you chose not to resto it, you may be able to salvage the motor, trailer & parts & pieces off the boat. And take some time to crawl all over it, and put your hands on as much of the interior surfaces as possible, bilge, seat boxes, storage compartments. You probably won't want to try & core sample the transom before you agree to take the boat from it's current owner. But you can take some pix & post them.
I'll need to find the thread, but until this happened, another iboater's hull & transom were thought to be structurally sound & safe for use, fortunately this occurred while unloading the boat at the ramp & not while underway:
If the boat you're look at looks like the Procraft I posted above, it can be rehab's. W/ some pix to see what you're working on, the guys around here will certainly rally & give you all the help you need, and then some....
