Mercruiser 3.0 starter bolts and bracket
kthkollar
Hello. Have a broken starter bolt on my mercruiser. I was wondering if anyone knew where to get new bolts, and also the bracket that is supposed to be on the starter, which as I am reading here, its absence most likely caused this problem. Thanks to all for your help.
jackd1023
Re: Mercruiser 3.0 starter bolts and bracket
Some were metric bolts if your block is stamped with a M it is a metric, otherwise standard starter bolts
garyfink
I bought a new permanent magnet one and it came with new bolts they are tiny compared to the old style and you don't need the rear bracket. For 80 scoobs you can't go wrong.
Capt Ken
You always need the rear brace with the 3.0. It will twist and break the bolts again if you don't.
kthkollar
Garyfink, I thought that too. Now I am taking the motor out to remove broken starter bolts. Still need info on the bracket. Is there one available or do i have to fabricate one? Thanks for any help.
Ayuh,... That's what I'd do,...
garyfink
I just gave mine away to the place I got my starter from. I'm sure they're still available from merc.
Don S
keep in mind, those brackets are not all the same. They change with the type of starter, and they year of your engine.
