Hi guys/gals, I'm new to this forum. Lots of good info here. Thanks for that.
I've made a new friend and he has a Wellcraft with an Ocean Pro 200. He has discovered that I possess pretty extensive mechanical skills and has asked me to help him with some minor issues with his motor. So we went fishing last week so I could catch some fish and also have a look at the problems he's been experiencing.
The motor is a bit rough on start up...although it wasn't too bad on the day I was there. Lots of smoke and vibration/missing on initial start. (he goes out often, twice a month usually) He says sometimes it dies continuously even after he's been to the bait boat. But once he's had it up to speed/temp and good and cleaned out it's fine the rest of the day. I experienced a bit of cold start issue and it was fine from the launch doc after a few minutes...although a bit rough at odd times. And when we were motoring in on our return through the no wake zone the motor was a bit rough...seems to have a low rpm miss later in the day when it's warm too...and he says that day it wasn't as bad as it has been recently on return to the launch doc.
Also about 15 minutes after first start, we were motoring thru rough seas at about 30mph and the motor gained a few hundred rpm without input from the throttle. It only did this one time that day that I noticed but he says he has experienced this before on other occasions.
So this next week I plan to dig into it for a tuneup...probably a thorough carb clean and setup check, new spark plugs and timing check, combustion chamber decarb, check the fuel pump and boat fuel system as described in threads here, and water pump impeller and oil change while I'm at it. I have an OEM Evinrude Service manual on the way. He provided me with a Seloc and imo it's crap...as you all have indicated.
Anything I should be particularly sensitive to while I'm completing all this maintenance? Your thoughts are greatly appreciated and thanks in advance for any and all help.
-Eric
-Eric
