Fuel pump wiring
brian1221
I have a 5.0 GIPEFS serial number 4012005198 and I was on here earlier with fuel pump questions. Well after the advice of the local mechanics in my town I purchased a new high pressure pump and then purchased the entire fuel pump assembly. So I am back here to get good advice, I installed the new pump and it seems to be running fine. Won?t know until I get it on the water and can check the fuel pump pressure's under a load. Know finally to my question does it matter which wire plug I hook up to which pump. One has what looks like an extension on it so it is longer. There is no difference in the plug besides that so it could connect to either pump. Thank you for your help in advance and have a good one.
