Need help, 1994 Freedom Wheels Trailer, Cobalt 252
rwarren4492
Just bought a 1995 Cobalt 252 on a 1994 matching trailer. Trailer sticker says it's a 1994 Freedom Wheels. It's a tandem axle with surge brakes. I need to replace the master cylinder but it is in the trailer frame and can't be removed. Anyone seen this??? Surely a trailer wasn't built with a non-removable master cylinder. There are no bolts anywhere around the master cly.
Anyone know this trailer??
Thanks,
Robert
Re: Need help, 1994 Freedom Wheels Trailer, Cobalt 252
Thanks,
Robert
Ayuh,... Welcome Aboard,.... Got some Pictures,.... Everything is "Fixable" in My world....;)
rwarren4492
Dark out now, but thought I'd try. Can master cylinder be welded into trailer frame? Why would Man. do that? Must be something I don't know!
Thanks for your time!
Ayuh,.... There appears to be a bolt just opposite the yellow sticker, in the 1st picture,...
Bet there's another 1 on the other side...
rwarren4492
The head of those two bolts sit against the frame I can only turn a couple times and it hits the frame. Guess I'll have to take to a trailer shop and get robbed.
Thanks
bryanandmissy
rwarren4492,
Did you ever get your trailer surge brakes fixed? I have the same exact trailer and am running into the same problem. What was your solution? Did you have to weld? Did you find the master cylinder?
Thanks,
Bryan
