Re: Do greaseable hubs need to be packed?
A little education for you: Basically, grease is an oil held in suspension in a "soap" base to thicken it. This prevents it from "slinging" out of the bearing.
Roller bearings need a surprisingly little amount of lubrication--think about the 50-1 ratio that outboard engines use. Look at the front bearings in a rear wheel drive car or truck: The factory only puts in a dollop of grease, just enough to pack the bearings thremselves while 90% of the hub is left empty. Admittedly, these hubs are not immersed in water regularly, but then again, neither are they repacked regularly--usually for the life of the vehicle
So BB or E Z lube, if you pump in grease through the fitting, enough oil will weep out and will get to both bearings to lubricate them. As long as the seals do not let in water, there is no need to remove the hubs and pack them and the bearings.
In fact, I have one trailer (for a tin boat) with leaking seals so I pump the BB full before each trip. It gets a lot of grease inside the fenders but that is the only harm so far. It has been that way for--oh, conservatively say ten years-- and I wonder if the bearings will ever fail. Someday I will remove the hubs for inspection--if I live that long.
While I sincerely embrace the concept of preventive maintenance, I don't go about making a ritual of it and don't prevent what may not be a problem. If seals started to leak on my 20 foot trailer, then I would definitely change them and repack the bearings. Until they do show a problem, I will simply pump in some fresh grease each season.
