Whats the name of the wiring harness that comes off the front of the throttle control
woodsyfeller
Im trying to purchase the wiring harness that comes off the front of the throttle controls on a quicksilver control I need the one that runs from the controls to the tachometer ect. When I do a search I just get the harness that goes from the control to the engine.
This may seem like a no brainer but some times having the right keywords makes all the difference on a web search.
Silvertip
Honorary Supreme Mariner
Re: Whats the name of the wiring harness that comes off the front of the throttle con
That is the harness that feeds the instrument panel and is probably a "boat specific" harness and not generally available aftermarket. If all you are after is the short harness that feeds a tac via the receptacle on the control box, that is simply called a tachometer harness.
