trackerman18
- Aug 8, 2012
- 7
I had the problem of my motor stalling when it idled in nuetral so I removed and cleaned the carb and reinstalled it and the problem dissapeared, only to start a new problem. I adjusted the idle screw so that the motor would idle at 800 in gear with the motor in a can of water. It will idle perfect now all day long, but when I throttle it up a little and go back to nuetral it is at about 1200 rpm or higher and won't go back down until I adjust the throttle arm with my hand. Is there a proper way to do this and is there a good manual I can get for a resonable price that shows these steps. I had purchased a Seloc manual for my engine but it seems not to cover my particular modle in enough detail that I can figure this out. New to boats, any help would be appreciated, want to start fishing soon!
