Grinding noise on Cobra 3.0 Outdrive
Tatoc
I have an OMC Cobra 3.0 liter engine with a 3.0 Cobra outdrive. The problem I am having is that when I shift it to forward I hear a grinding noise. To test it, I left it on forward then went and lightly put a broom to the propeller, and it stopped spinning.
Can anyone tell me what is causing this problem? And how to fix it.
PS. Everything seems to work great in reverse.
Re: Grinding noise on Cobra 3.0 Outdrive
Ayuh,.... Welcome Aboard,... Drain the drive oil, 'n look for metal...
Tatoc
I'm on a business trip at the moment, but when I get back I will do that and get back to you.
Thank you.
