ksmith3846
- May 11, 2012
- 7
i have a 93 200 yamaha txrr i was having surging problems but i narrowed that to where i was getting air in the fuel lines but i thought i was having a slight firing problem. So before going out just for a test run i replaced all the plugs on the engine. The engine ran a little rough and only reached 4200rpms so i pulled the plugs out of the engine to check them all and one plug was completely clean but all the others were a little black from burning. i have just recently went through the whole fuel system from the boat to the engine and on this older yamaha it only has 3 carbs not like the newer ones that have one carb per cylinder it ran great before but now it runs rough and is hard to keep it at low idle. i checked the spark on the engine and that plug it not getting any fire. how would i trouble shoot to see what the problem is?
