First trip of the season motor over heated while idling within 30 minutes.
Have tried all of the obvious trouble-shooting solutions. Changed pump housing and impeller. Installed new thermostat. Separated top and bottom drives and inspected grommets, seals and tube...all looked OK. Checked to make sure impeller shaft was turning and it was. Ran water through all inlets, ports hoses and exhaust...no blockage. Water flows fine out of inlet hose to thermostat when the muffs are used. When I put the boat in the water, the water flow through the inlet hose is sporatic or not at all. Totally baffled
Any suggestions would be greatly appreciated.
Thanks in advance
Dwight
Thanks in advance
Dwight
