Yamaha F150 and fuse?
AEW
About 11:00pm last night trying to get the boat ready and installing a new battery the cables got reversed and apparently took out several fuses.
I should know better to do electrical when tired, dark and using only a flashlight, but it rained most the day and the boat sits outside.
I now have the T-8 kicker and everything thing else powered, but the main motor (the F150) is dead.
Fuses on the main fuse panel appear to ohm out good and one of the 50 amp fuses has power to it, one doesn't.
Is there another fuse somewhere, maybe an inline one or???
Tilt and trim doesn't work on the big motor also.
Help?
TIA
Al
cspierings
Re: Yamaha F150 and fuse?
Help?
TIA
Al
I just did the same thing and have the same issue. Did you ever get a resolution?
Thanks
cspierings
I got a tip to check the 50 amp main fuse from guy on idofishing. That did the trick!
