biggrhammr
- May 1, 2012
- 26
Seems that running an outdrive low on oil is a common problem. I bought my first boat a couple of months ago, and even though I knew from the research I had done before I bought it, that there were numerous things I should have checked before taking it out the first time, I went out anyway. I checked the oil level of the drive when I bought the boat, then ran it in my driveway several times before taking it out. I never vacuum tested it though. It lasted about 30 minutes before it lost enough oil to ruin the top end ( I think the water impeller sucked it out via the shaft seal). Anyway, could a person not just attach a ?drip oiler? to the top of the outdrive (this is on an OMC Cobra) ? This way even if you did get a leaky seal while out on the lake, you would have time to deal with it before the drive destroyed itself? It seems as if you had the same amount of air in the top of the oiler as you do at the top of the drive, then whatever pressure build up (if there is any) would compress that air the same as it would have before. Not sure if the dipstick hole would be large enough to allow the oil to ?drip? due to the viscosity of the oil though.
