So where are ya? Near Spring Hill?MinUph Thanks! BTW we are neighbors, I'm in NC FL
I have a bilge pump on the rear of one of the tubes, and works well so that much is there. Was also thinking of a removable type. Any thoughts on the material I could use to make one? Inexpensive 40qt or larger cooler?
Thats what I use - I also used PVC with valve to plumb it though the floor to partialy drain to add fresh water-Works great.
I'm heading in this direction. I ordered through the hull fittings for the 3/4" bilge tubing. Thanks!
You can get Livewell timers off ebay for 25-40$, Mine Is ON 1 minute, OFF 5 minutes. Keeps the fish lively all day.I think you'll like it- I thought about a areator but it just takes a few seconds to flip a switch & pump fresh cool lake water into it-
