doesnt go into reverse unless manually
i changed from a 1987 90 hp johnson to a 1977 johnson 115hp will the 80s control box work or do i need the power pilot
Haffiman
Re: doesnt go into reverse unless manually
Should not be a problem using the later control. Check bushings in engine linkage system if problems.
boobie
Do you have the shift cable adjusted properly on the mtr ??
