Alpha 1 Gen 2 Waterpump Install Question
jmcdona
I have a 1991 alpha1 gen 2 that I'm about to replace the Waterpump assembly and shiftshaft bushing on. I have a few questions before I proceed:
1) I've read in the factory manual that you need to rotate the driveshaft clockwise while lowering the waterpump housing over the impeller. My drive shaft seems to be in a locked position regardless of the shift shaft position. Do I need to just force the issue? Please note that I have not yet removed the shiftshaft bushing assem, or the old waterpump. I'm doing some prelimnary checks prior to replacing it.
2) There are a couple of references of Perfect Seal. Are there any substitutes that can be obtained?
3) Is it recommended to use bellows adhesive to retain the quad seal (the quad is the orange colored o-ring in the picture)?
stonyloam
Re: Alpha 1 Gen 2 Waterpump Install Question
If you turn the shift shaft half way CCW it should be in neutral.
NAPA (Permatex) aviation sealant.
I just use a dab of grease.
Don S
That is done to get the impeller vanes turned the right direction while installing.
Friction of the impeller may keep the shaft from turning easily, you also have it in forward gear in the picture. If the prop is still on and blocked so it can't turn, that will also keep the shaft from turning.
I always do, cheap insurance and I always had it handy, so why not.
It can cost you a drive if it gets knocked out of position and you don't notice it. Your choice.
