mercury 70 hp 2 stroke outboard rebuild advice
rammed wx
hi guys
just looking for a bit of information and advice.
i am new to the site so hopefully this makes sence haha.
ok i have just bought my first boat which has a old 70 hp 2 stroke 3 cylinder outboard.
i am looking to rebuild it or at least get a bit of information.(just engine at this stage)
i am an engine builder by trade but have had very little to do with outboards especially 2 strokes.
so what i was wondering is firstly does anybody have engine specifications (with full tensions,piston over sizes,crankshaft sizes etc) or does anybody know where i could find them. even engine diagrams
and also could anybody direct me with gasket kits,bearings or just anything you could suggest i would need.
or just generally any advice.
any help would be greatly appreciated
thanks in advance
clint
carholme
Re: mercury 70 hp 2 stroke outboard rebuild advice
Clint;
Do you have the s/n of the engine?
Gerry
Faztbullet
Piston over sizes are .015 and .030 other sizes are available but it don't suggest that brand. What crank speck ya looking for? Check cylinders for taper as all inlines wear around the ports.
captainredbeard
hi guys
thanks in advance
clint
Hi guys i also have an mercury 70 hp 2 stroke 3 cylinder outboard and was looking for engine spec and any other information or maunals
rammed wx
ok great news. so it is possible for a bore and hone with out sleeve replacement.
crank specs i am looking for are standars sizes for big ends and mains and if you can grind them if worn for undersize bearings.
basically thats why i need specifications and sizes to measure and inspect everything to see what is reconditionable and avaliability of pistons bearings etc.
thanks alot
carholme
Clint;
Your s/n comes up as:
70 70 3-cyl 4571652 4825848 1977 USA
From here:
http://www.marinshopen.se/Motorer/O...Mercury2takt3cyl6090hp/tabid/486/Default.aspx
Parts Listing:
http://www.crowleymarine.com/mercury-outboard/479.cfm
Service Manual P/N: 90-86135--5
http://www.ebay.com/itm/USED-93-Mercury-Outboard-45-50-4-Cyl-Service-Manual-/270801861441
In the interim until you get a Merc manual, here is a link to the condensed version of the Clymer manual. Let the page load for several seconds and then download soonest to your computer as the link is short lived.
http://web.ebscohost.com/serrc/pdf?...c-9565-ebced3a5b401@sessionmgr14&vid=4&hid=11
Gerry
Faztbullet
Nope..... bearings only come in one size and in over 40+years of wrenching never see a worn out crank as everything internal is roller/needle bearings.
rammed wx
Clint;
From here:
Parts Listing:
Gerry
thanks gerry
rammed wx
Has anybody built one of these engines before as I would be interested to know what they have done in terms of performance modifications
